Metrohm 761 IC
I have a 761 Compact. I was wondering what is the version of IC Net software I
need to run on this instrument. Also can I use an external detector with
this instrument, (waters 410 RI), if so do I need an interface?
Thanks in advance
Have a 761 compact too, I use IC Net 2.3 to run the instrument. Sorry I don't know if y can use the waters 410 coupled with it
You can take the analog signal from the back of he 410 RI to your "computer" if it can take analog signals.
this instrument, (waters 410 RI), if so do I need an interface? Thanks you
for all your help.
Thanks in advance
C.Tony Vella Royal British Legion
WWW.HPLCworks.net
858.663 751
Arte et Marte
Dear ilawrence
Sorry to answer so late.
The latest software version is ICNet 2.3 SR6. you may download it fre of charge from the Metrohm Software Center.
To connect an external detector you need the 771 IC Compact Interface.
Dr. Markus Laeubli
Manager Marketing Support IC
(retired)
Metrohm AG
9101 Herisau
Switzerland
Thanks Markus
Users browsing this forum: Semrush [Bot] and 9 guests
