thanks
firstly thanks for yours helps
is there somebody do this analysis begin to end?
can you explain the rows singly.İ aproached a method use it but I couldnt to draw calibration curve
I give my sample 1 ppb,3ppb,5ppb... but I take the area decreasing not residual.,
thanks again...
Your question is a bit cryptic. Could you give us some details on what you are trying to do?
we must do napthalene analysis in honey with gcms.thanks again your interest.
That does *not* constitute details! Wea re not mind readers.
What instrument? What column & conditions (flow, temperature program, injection volume, etc.). How are you prepping the sample? How much are you injecting? what data system are you using?
I tihnk this follows a thread that I saw some time back and probably should have continued there...
Users browsing this forum: Bing [Bot] and 2 guests
