Py-GC/MS and split ratio
I work with a Pyrolysis-GC/MS system. I use polystyrene as standard.
I can observe on the pyrogram styrene monomer(major peak), dimer and trimer.
Pyrolysis temperature has an influence on percentage of dimer and trimer. At 750°c I have less trimer than dimer.
Currently my GC method use a split ratio 30:1; but when I use a split ratio 50:1, trimer peak is higher than dimer.
I don't understand how split ratio can have an effect on high boiling compounds? Is it specific to the Py-GC/MS system?
Anyone have an explanation?
Thanks!
Damien
Just a thought:
Could the cooling effect of the larger gas flow (50:1) cause a reduction in breakdown from trimer to dimer/monomer products? I.E., if thermal degradation is the process to take POLYstyrene into mono, di and tri-mer versions the added cooling effect of the increased split might be causing your problem.
~Ty~
Thanks for your answer.
So an increase split create a cooling effect in inlet? I don't known about that.
But it can explain the phenomen. The breakdown of polystyrene is made in the pyrolysor
chamber, but a temperature decrease in inlet could form more trimer (reaction between monomer and dimer)...
Thanks again!
Damien
Sorry, I had the symptoms backwards in my head. I was thinking the trimer was decreasing with increasing split. Now it makes even more sense. I read about the cooling effect in an article about ultra fast GC methods once. The split rates were between 100 and 400 mL/min so I'm not sure if you would see such a noticeable effect going from 30 to 50. It's just the only thing I can think of.
~Ty~
Okey,
Thanks for your help!
Total flow presumably has some effect on residence time in the pyrolyser, and the longer the residence the more the fragmentation.
In total there are 64 users online :: 0 registered, 0 hidden and 64 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 64 guests
