In line filter/pre column
I wonder if an inline filter (ex. 2µm) is useful if i alredy use a precolumn in order to avoid inlet frit plugging....and backpressure increase.
Please give me an advise.
You want to guard the guard? Next question: Should one guard the guard with a guard?
Well, seriously, an inline filter (frit, sieve) between the pump and the injection valve is not a bad idea, especially if your injection valve is connected with 0.1mm capillaries.
I used to have a couple customers (a previous job) who never filtered their samples before analysis. They just changed the 0.5 micron pre-column filter once a day. They never complained about column life, but sure did if we couldn't ship frits on time!
Mark Tracy
Senior Chemist
Dionex Corp.
I have always taken the position it is better to protect my column than justify a replacement. A small guard disc is much less expensive than a guard column or column. There are several on the market which have proven to perform well without sacrificing the separation. I have successfully used inline filters from Upchurch, RP or Universal Disc technology from Transgenomic and the Metrohm RP Universal Guard Disc. Phenomenex and Alltech also have simliar products I just have not used them personally. These are inexpensive and they do protect your column investment.
In total there are 16 users online :: 2 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], John Guajardo and 14 guests
