Millennium 32 calculation query
Does anyone know how to quantify samples in Millennium 32 with just the standards in the brackets nearest to them?
Michelle
When you set up your sample set using the wizard, use either of the last two choices in the "Select Location of Standards" window. One is for bracketing standards with overlap, one is for without overlap.
If you don't use the wizard, you can use the label and label reference columns to select which standards to use for which calibration.
