TLC: Rf value of 0 using 90/10 acetone/hexane
Just doing fractation at the moment and after collecting a number of samples my tlc spot of the current fractation is not mving on the tlc plate. What can i do? Im using 90/10 acetone hexane
Have you tried other solvents? What was the sample disolved in before you applied it to the TLC plate? This may help with selection. Depending on the soluabiity of the sample, you can try a number of other directions - 100% acetone, 100% hexane, methanol, THF, chloroform, ... and the list goes on.
(And some things will never move on a given stationary phase.)
Users browsing this forum: Bing [Bot] and 12 guests
