Inficon 3000 Micro GC
Does anyone have experience with Inficon 3000 micro GC ?
Trying to get one and have some questions.
The application is to analyze syngas with some light hydrocarbons. The model offered has a 4 th channel which is a fixed volume injector an all purpose non polar column.
Is this channel really necessary for our application?
What problems have you encountered with this model ? Are there any frequent or common problems with this type ?
OCRC,
The 3000 was Agilent's micro before Agilent bought out Varian. Agilent took Varian's version and spun off their version to Inficon.
What I have seen of Agilents: very quick, very reliable, impossible to work on, expensive to repair but don't need to repair that often. Based on the last two comments, I am trying to convince a customer of mine to look at a full size chassis for RGA analysis but have to demonstrate something close to the same speed of analysis for the full suite of components (~2 minutes.)
The fourth channel is meant for measuring heavier hydrocarbons (C 6+) as a lump at the end of the chromatogram. If you are sure you won't have that, you can probably get away with only the first three channels.
Best regards,
AICMM
Users browsing this forum: Bing [Bot] and 11 guests
