Not able to see select over lay window
Good morning, I am new to GC-MS and running a method using FID method for blank and high neat cal. I have loaded the data file in GC-Data Analysis and it was loaded as usually.
From there I went to view, chromatogram overlay: the real problem is select over lay mode window doesn't shows up. On the opened data file it shows : view mode: integration.
Does anyone has this kind of problem, any suggestion to resolve this issue?.
Rao
It would be helpful to know what instrument and software you are using.
It would be NECESSARY to know what instrument and software you are using.
