Acidity effect on derivatization
Hi guys/gals.
I am derivatizing with IBCF a sample in 0.1 molar HCl. I have another sample that had been prepared in 5 molar HCl and dried. If I am going to re-hydrate with 1 mL of water that mean the sample HCl molarity will go back to 5 molar. Can I proceed with the same derivatization as 0.1 molar HCl or should I adjust the molarity form 5 M to 0.1 M HCL. Also, it is very difficult to adjust the molarity because I will loose the sample concentration.
If you have a sample that was in 5 M HCl and was evaporated to dryness, you have probably lost much or most of the HCl to evaporation.
[quote="Don_Hilton"]If you have a sample that was in 5 M HCl and was evaporated to dryness, you have probably lost much or most of the HCl to evaporation.[that is great thank you don]
In total there are 31 users online :: 0 registered, 0 hidden and 31 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 31 guests
