volume of sample to load on column??
Dear all,
I am working on the separation of bacterial beta galactosidase enzyme from the mixture of protein sample. Doing conventional gel filteration chromatography for this purpose. Resin is Sephadex G-100.
Kindly suggest me how much volume of sample should i load on column?? My sample contains 1.2 mg/ml of protein.
Column height is 80cm and width is 2.2 mm.
Kindly reply as soon as possible.
Less than 5% of column volume, around 1-2% should be OK.
Double check those column dimensions. Are you sure you didn't mean 80cm by 22mm? Otherwise that sounds like a very impractical column for your purpose, which I'm assuming is prep scale. Also, that would be an incredibly fragile column.
thanks for your reply
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 26 guests
