How to Calculate the Accuracy of GC Analysis?
Dears,
Can any one help me in calculating the accuracy of an on-line Gas Chromatograph analysis when the accuracy (+- error) given by GC manufacturer is 1% of the range of measured component and 2% by Calbration Gas supplier.
Would it be calculated by formula as follows, (old time learned)
Analysis Accu= squar root of (1)2 + (2)2 = +-2.449
(Description: Squar root of GC accuracy square + Calibration Gas accuracy square)
Thank You
Athar
First of all, I think you are referring to precision, not accuracy.
And yes, the precision (relative standard deviation) is the square root of the sum of the squares of the independent contributions.
Users browsing this forum: Semrush [Bot] and 9 guests
