different retention time though the methods are the same
Dear users,
I am seeking an answer of a strange phenomenon in my GC-MS results. I conducted an objective analysis using GC-MS towards a certain papaya variety extract to see the volatile patterns. The result showed that naphthalene occured at 30.45 minute. I conducted another test using the same method and column but different papaya variety. The result was naphthalene occured at different retention time: 37.12. What had happened?
One or both of the peaks that the MS search says is naphthalene, is not naphthalene Or a system fault, or operator error.
Thank you, Mr. Peter. =]
Look for the match with the library ; is it higher for one of the compounds ?
Which software are you using ? ChromaTOF is known to find a lots of "false positives".
You really need to compare with standards to confirm compounds retention time.
Hope that helps,
Fée
Users browsing this forum: Google [Bot] and 11 guests
