Calibration curve of standards
Hello to everyone,
I have run various concentration of organic acids (0.1, 0.5, 1.0, 5.0 uM ) in GCMS after extracting and derivatizing to get a calibration curve.Igot the standard curve but the response ratio for some organic acids ( methylmalonic acid, glutaric acid, 3-methylglutaric acid, adipic acid and sebacic acid ) is 2,4,6..etc and the response ratio for some organic acids ( hexanoic acid, butyric acid, propionic acid,isovelaric acid and suberic acid) is 2.1 + e8, 4.1 + e8, 5.4 + e10...etc.Out of these two which calibration curve is correct.
Chandra
This is a question that is probably better to ask your advisor or supervisor or something. You could also review the theory of calibration curves and that should answer your question: http://en.wikipedia.org/wiki/Calibration_curve
For things you want to quantify using the curve, they should fall on the linear region of the curve.
In total there are 26 users online :: 2 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 24 guests
