sample is doesn't fully dissolve and is a gel
I'm working with chitin. I want to get it fully dissolved in solution.
I made a 2 mg/mL mixture with 5% LiCl in DMA as the diluent. The material appears to be mostly transparent. I was hoping to remove large particles/aggregates/gels by filtering through 0.45 um membrane. This just clogged the membrane.
I was wondering if there is a way to remove these large particles/aggregates/gels and leave only the most soluble and best behaving species from chitin in solution.
I think the gelling and aggregation is due to greater molecular weight, but I am not sure of this.
Any help would be appreciated.
MestizoJoe
Analytical Chemist and Adventurer
Venture Industries
Spider-Skull Island
if you want to remove large particles try centrifugation
"If your experiment needs statistics, you ought to have done a better experiment." Rutherford
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 26 guests
