AOC-5000 and MHE
What is best way to set up an MHE run? I have Combi PAL, Cyle Composer, GC Solutions (Shimadzu) and the AOC-5000 "game boy" to deal with. Seems like some combination of one or some of these parts should work for doing (for example) repeat injections (5) on a and then move on to an unknown and do 5 repeat injections on that sample.
I'm close in that I stopped GC Solution from taking remote control of the AOC-5000. That allowed for the timing of incubation/agitation to coordinate better, but I still can not get AOC-5000 to do repeat injections on the same vial. My service guy recommended setting up multiple "Jobs" on the game boy, but that didn't work either because I keep getting the "memory full" message on the game boy.
HELP!
Cycle Composer should allow you to configure repeated injections as part of a sequence. Instead of setting multiple "Jobs" on the AOC-5000, you could use Cycle Composer to define a single job for performing repeat injections (for example, 5 injections per sample) by incorporating loops. Stickman Hook
