DAC column(Dynamic axial compression column)
With the development of Pharmaceutical and Biochemical and other relevant Industries rapidly,Preparative HPLC Separation and Purification Technology is getting more and more widely used and developed.It is the most important method for Complex compounds of Separation and Purification
Especailly for Natural Product and biomolecules(Peptide,Protein and so on).In order to get the desired separation ,The chromatography Column packing should be met with some requirements that are the Continuity, homogenization, stability and tightness.
The Chromatography Column Packing,especially Industrial Production Scale packing which has Big diameter is very difficult. The traditional Packing Method can be devided into dry packing and Slurry Packing.The dry packing is clumsy and Column Performance is not good and The Packing Materials is very easy to distribute around the Column Wall when you pack,But Slurry Packing density can not be distributed uniformly.The density that is close to column wall is very high and the reproducibility of Chromatography Column is bad..If the Column that has a big diameter is packed by traditional method,then the column bad is not stable and it will reduce the separation performance….
But,Dynamic axial compression technology is considered the best packing technology in the world(The inner diamater above 50mm),The working principle adoptes the Piston packing(Slurry packing),It will keep the compression of Column bed for ensuring the stability.If the column is pakced by DAC column technology,It will have the high performance,High density,High Column efficiency,High repeatability. Until now, DAC column is gradually dominate the High pressure Preparative Separation and Purification market.
Have you ever used Dynamic axial compression column before? Which brand you used? from Hanbon,China?
Dr.Darren
Preparative Process Engineer
Dear Dr.Darren
as you know, the DAC are more and more used in the separation with High pressure preparative chromatography system .Which data you want to know ,you could send the E-mail to me: caixin@lisui.net , i will reply your question about the DAC.
Our company is one of the manufacture of the Process preparative chromatography system.
Web site;http://www.lisurescience.com/en/
CAIXIN
Flash Chromatography Made in CHINA
Users browsing this forum: Bing [Bot] and 2 guests
