mobile phase issue
10 posts Page 1 of 1
why mobile phase getting hazy below 20 degrees temp
mobile phase is SLS
With Warm Regards
Pr. D.Sudhir Kumar M.Pharm
Research Associate-IV
AUROBINDO PHARMA
lessened solubility?
but at room temp its stable
With Warm Regards
AUROBINDO PHARMA
Sounds as if you're just at the edge of solubility at room temperature. A few degrees down at the SLS starts precipitating:(
Its not about stability only, it may be due to solubility. The solubility of a compound also differs at different environment and temperature may be a factor. Try to warm up the mobile phase once you get hazy and see the difference. If the soltion becomes clear, may be its the temperature.
Are you using any potassium salt in your mobile phase?
mobile phase is SLS
Sorry I'm not a natural speaker: What means 'SLS'?
mobile phase is SLS
SLS Sodium lauryl sulfate
With Warm Regards
AUROBINDO PHARMA
I suggest that you switch to mixed-mode where IP reagent is attached to the surface.....or add a little bit of THF to your mobile phase
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
we are using sodium dihydrogen phosphate anhydrous
With Warm Regards
AUROBINDO PHARMA
