Amino Acids in a dicarboxylic acid
Hi-
I am trying to find any amino acid impurities in a dicarboxylic acid. I'm using the Waters Accq-Tag system to derivatize the amino acids. But for some reason, when I run it on the HPLC, none of the amino acid peaks are showing up. When I run a standard amino acid mix without the dicarboxylic acid, all of the peaks are there. Could something in the dicaboxylic acid be interfering with the devitatization? Would I be better off trying a different derivatizing agent? Please let me know.
Thanks!
Just in case anyone cares or has a similar problem... we figured out that the pH of the solution was too low for the derivatization, so we added NaOH until it was closer to neutral.
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
