LCQ Deca XP Plus (Thermo)
I am working with the LCQ Deca XP Plus/Ultimate Plus/Famos since 1 month. I need to set up the instrument and develop few analytical methods for the company I worked with. The instrument was bought second-hand 4 years ago, there is no services nor maintenance contract for it. I am pretty much on my own and need to discuss to people who has already work with these instruments and the Xcalibur software.
Chemex, I don't have any experience with the system you have, but i do have some experience with Xcalibur software. What do you want to know about the software?
To create an instrument method, I need a tune method. Can I do a tune method with more than one compound (3 in my case)? I think I can using the MSn mode in Define scan button (Tune plus). Can you confirmed this please?
Does it means that I have to do a MS/MS experiment for each compound (to find the parent mass) and then joined the parent masses in one tune method?
Another question is about the start up/shut down method (intrument methods) that we can use before and after running a sequence. It is suggested (in the manual) that these methods can be use for example for tuning or calibration. My question is how can I create a tune/calibration method from Xcalibur as the method one required a steady infusion of the tuning/calibration solution using a syringue into the MS?
Thank you for any help you can bring me.
Hello to all
For the Xcalibur software, when to use LC Quan vs Quan Browser?
Many thanks
Users browsing this forum: Semrush [Bot] and 15 guests
