Buffers that Are Volatile And Have a Low UV Cutoff
Hey all
I want to ask a question. Can anyone recommend buffers (or acids) that are both volatile and - at the same time - have a low UV cut off.
I can think of examples that fit one category or the other, but none that fit both.
Much Thanks
There are no such buffers...
All volatile buffers are organic acids or salts thereof = signficant UV absorption below about 230 nm. The only option is too keep the buffer or acid concentration low, to be able to get a useful UV signal.
You can try with ammonium bicarbonate (NH4HCO3).
It has no UV absorption (> 210 nm) and is suitable for atmospheric pressure ionization sources for MS.
One important drawback: it is not suitable for preparation of low pH buffers
So there is really no option, if one needs to look at low wavelength UV and do evaporative light scattering detection at the same time (which requires a volatile buffer).
TFA, Acetic Acid, Formic acid, Acetate (K), Formate (K), Ammonium Bicarbonate 10mM could be used. Please remember that adding organic solvents UV-cut off is changed.
