GC-MS of oxetanes
Can anybody suggest column/solvent conditions for analyzing simply substituted oxetanes
by GC-MS
Niki
Just only my idea, not true story.
If this oxetane is paclitaxel (MW. = 854), which an active hydrogen molecules on the structure.
Try to derivatise with MSTFA or BSTFA for get volatilable property for GC/MS analysis.
Column : Non polar capillary column (Phase #-1 or #-5), try to use short 10-15 mater.
Oven temperature : Start at 150 degree-C or higher to maximum temperature around 330 degree-C, hold at least 5 min. for survey scan.
Because this compound easily fragements to small mass units lower than 400 amu. (see NIST library), then, you can use normal tune (atune) in this experiments.
Jetjamnong
Users browsing this forum: Bing [Bot] and 2 guests
