Low pressure+1100 LC+six port valve of triple quad
There is a drop in cap pressure after valve switch from detector to load; the starting pressure is 60 bar but after valve switch it stablizes at 10-12 bar. What are the possible causes? I have made sure there are no leaks!
Is this an Agilent triple quad? The rotor seal and/or stator face in the MS switching valve may need replacing or there could be a blockage in the waste line. You can remove the switching valve and try giving all the bits in there a clean to get a bit more life out of it.
In total there are 20 users online :: 1 registered, 0 hidden and 19 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 19 guests
