gradient sloping downwards
Hi and thanks in advance for helping out.
I am using acetic acid adjusted to pH 5 with ammonium hydroxide on A and 100% MeOH on B and I am monitoring at 230nm using a phenyl column. My problem is that the baseline slopes downward and I would like to correct for it and don't know how, any help would be appreciated.
your going to get slope when using a gradient you really cant help that. . You could try to raise your wavelenght higher to a region where there is less absorption but you may lose sensitivity or you could go isocratic
Hi Shadow,
Acetate and 230 nm detection is a bad combination. Use another acid/salt instead of acetic acid/acetate.
What is the pH in you mobile phase by the way?
Users browsing this forum: Ahrefs [Bot] and 15 guests
