empower calibration reporting problem
Hi ,
Im trying to add a calibration curve plot and data into empower 2 reports, but once added the report it seems to show a number of calibration plots. (not just one for standard)
I have tried to reprocess sample set with clear calibration but still I get a number of plots when I look at report publisher
All I require is a plot at the end for standards in sample set.
Also what is this best wat to filter this data (ie just one plot shown in report)
Any help would be great
My background is in Chemstation and Chromeleon,which were a doddle and much more user friendly compared to Empower, in my opinion ! (or should that be Milllenium 32 with add ons !)
Check Overlay settings.
If the problem is not there, are you using "Normal" for standard processing in the sample set method, then using a "Calibrate" line after injections? This can result in duplications... If this is the case, either change standards to "Don't process or report" or delete the "Calibrate" line.
