Sample preparation for Organic Solvent
Currently my lab is direct inject the organic solvent into GC without any sample preparation step. I do not know whether the sample is required to remove moisture or not.
If yes, anhydrous sodium sulfate is it sufficient enough?
What solvent and what are you trying to analyse for? If you're just QCing raw materials for %area then it's fine.
ACETONE, BUTYL ACETATE, BUTYL CELLOSOLVE, CELLOSOLVE ACETATE, ETHYL ACETATE, HEXANE, ISO-BUTANOL, IPA, MIBK, MEK, METHANOL, N-BUTANOL, TOLUENE, XYLENE, DEA, DEG, MPG, MEA, MEG, MPA, TEG, ETHOXY PROPANOL, AMYL ACETATE,DIMETHYL FORMAMIRY,CYCLOHEXANE.
Yes i'm doing QC, our company is doing solvent repacking and blending.
What's that ? Is it dimethylformamide ?
Maybe...i not sure...i just take from the list in my lab
Can't be anything else. :wink:
In total there are 87 users online :: 3 registered, 0 hidden and 84 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot], Google [Bot], Semrush [Bot] and 84 guests
