pH adjustment
Why do we need to adjust the pH of the liquid sample to less than 2 prior to hydrocarbon extraction?
Thank you
Either to protonate acidic species and make them hydrophobic so they extract into the solvent, or to make basic species ionised to keep them in the water phase. So it depends what you're trying to achieve.
Johnny Red is correct. In the case of heavy fuels such as Diesel and kerosene, you are protonating fatty acids.
Don Shelly
Don Shelly Consulting, LLC
thank you for your reply. But why do we have to include fatty acids in TPH extraction when the aim is to extract the hydrocarbons present in the liquid samples?
If your goal is to extract fuel, fatty acids are part of that fuel.
Don Shelly
thanks for the reply. To my understanding, fatty acids are one of the metabolic products of hydrocarbon degradation my microorganisms. if we include them in the total hydrocarbon extraction, will this not create a bias in measurement?
Some refineries actually add fatty acids to the heavy fuels that that produce. I have no idea why. Try extracting a "fresh" diesel fuel with and without pH adjustment and you will see for yourself.
Don Shelly
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
