ULTRASOUND ASSISTED EXTRACTION?
I just came accross this method in several food analytical chem papers and was curious about it.
http://naldc.nal.usda.gov/download/42350/PDF
http://www.sciencedirect.com/science/ar ... 7701000669
http://www.ingentaconnect.com/content/t ... 5/art00004
I often use a Branson sonicator bath to help mix my samples. What kind of equipment do you need for it? It it mainly used for unprocessed plant tissue or flavors?
MSChemist,
In my opinion, US baths do not have enough oomph. That's why the EPA method for explosives has such a long extraction time.
Use a real US source.
Comparison of ultrasonic assisted digestion with traditional methods for alpha/beta analysis
D. Dale, G. Brooks, M. Monagle
Journal: Journal of Radioanalytical and Nuclear Chemistry - J RADIOANAL NUCL CHEM , vol. 236, no. 1, pp. 199-204, 1998.
Best regards,
AICMM
What type of equipment do you need. The type with the probe that goes directly in solution. I used that back when I was doing Mol Bio to lyse E. coli cells.
I would think something similar to this would be what you need
http://www.emersonindustrial.com/en-US/ ... fault.aspx
This is a link to the USEPA method for Ultra Sonic Extraction of Organics from Soils using the above type ultra sonic cell disruptor.
http://www.epa.gov/osw/hazard/testmetho ... /3550c.pdf
In total there are 33 users online :: 0 registered, 0 hidden and 33 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 33 guests
