ZONYL FSN-100
Hello there,
we are trying to characterize micellization behaviour of one of the nonionic perfluorinated surfactant sold by sigma-aldrich. From what I have found it is obvious, that the structure of this compound is a bit "mysterius" (probably a mixture of these molecules with various chain lengths). Mass of this mixture is around 950. Becasue I am not that good at chromatography, I would like to ask. If i will find a common solvent (maybe THF) for this molecule, what chromatography could I use to separate those molecules (so that I will know more about the structure). MOlecular formula is like this: http://www.chemnet.com/cas/en/65545-80- ... ctant.html
Thank you very much.
Juraj
ZONYL FSN-100 is 1:1 in dioxane solvent
CAS Number 65545-80-4
Linear Formula (C2H4O)x(CF2)yC2H5FO
Solubility
• >2% in water, isopropyl and methyl alcohol, acetone, ethyl
acetate, toluene, THF, and methyl chloroform
• Insoluble in n-heptane
Poly(oxy-1,2-ethanediyl), alpha-hydro- omega -hydroxy-, ether with
alpha-fluoro- omega -(2-hydroxyethyl)poly(difluoromethylene)
Note that the material is 1:1 in dioxane.
Hello Rod,
thank you for your answer. Where did you find this information?
Juraj
google search gave me the Sigma Chemical web site reference.
Here they say its 100 % surfactant.
http://evonik.tego.de/pdf/daten/amer/Zonyl_FSN_100.pdf
Juraj
It probably depends upon the source of your material.
I have no idea where you procured yours.
