NORMAL PHASE vs REVERSE PHASE IN POLYPHENOL ANALYSIS
Hello all,
I am requested to analyse alcoolic extracts of tannins (from oak) and some fruits (berries...) (in a powder form). I must compare and cross informations obtained by 3 methods:
Reverse Phase HPLC
Normal Phase HPLC and
Size Exclusion Chromatography
For RP HPLC and SEC there is no problem (I mean, I see what I can obtain : from the first one information on specific components of interest and from the second one I can obtain a MW profile of the extracts), but :
What kind of information can I obtain from NP-HPLC, which I cannot from the other 2 technics?
Are the interactions not only chemical in NP HPLC? (as I saw (from bibliography) that NP- HPLC is used to separate polymers in a similar way to SEC)
My questions are maybe too simple, but I'm not experienced in this field and I am a little confused... :? :oops:
Thank you in advance
Best regards
Carmen
Carmen,
NP-HPLC is based on sample/column interactions also except that in NP-HPLC the column is polar and the mobile phase is non-polar with a small percent of polar modifier. Sample interactions are based on the polar interactions between sample and column. NP-HPLC results are therefore, complimentary to RP-HPLC results. NP-HPLC is also used when the sample components are mostly non-polar and soluble in non-polar solvents.
thank you for your answer,
only after having posted my message yesterday I realised that I should have thought twice before...
Now I can see clearer :idea:
I have understood that actually, in my compounds polarity is related to size... that's why I had been confused! ... :oops: (my mind was not clear enough because of Monday!) :oops:
but thankn you anyway! :D
Carmen
