Air+ H2 OFF after run, instantly ON afterwards. Why??
Dear all,
I'm using an FID and I cannot understand why my air and hydrogen flow sets to "OFF" just at the end of the run, then instantly go to the set flow.
I've been using a GC before but with this new one I'm having this problem. I feel that it is not a problem with pressures (because the flow setpoint goes to OFF, doesn't decrease) but with something set on the method/sequence.
Any idea?
Thanks in advance,
We will have to know your instrument. If it Agilent I would check your lit offset value.
The instrument is Agilent 6890.
Thanks.
Dear all,
I managed to avoid the problem I described previously. It was just a problem with the movement of a valve. It was being switched too soon.
In total there are 38 users online :: 0 registered, 0 hidden and 38 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 38 guests
