Mass Hunter Qual Analysis - Method Error
Hi!
I have the Mass Hunter Qualitative Analysis SW B.04.00 installed (with SP2) in my laptop (HP W7 - 64bit) and any time that I want to use it, appear in the inizialitation step, an error as follow:
Agilent MassHunter Workstation Software Qualitative Analysis encountered an error. The program will attempt to continue ignoring this error. However we recommend saving the data and restarting the program.
The log has been created at C:\temp\AgtErrorLogs
You can read the error details at bottom of this topic.
This error apperar too when I try to load a method, and I can not work,!
I was searching in different web pages without luck.
As you can see in the error text, there are some spanish words, because my windows was set in this language, maybe this is the problem?
I really apprecciate if somebody can help me.
Best regards.
Patomb.
Date and Time: 06-06-2013 15:43
Program: Agilent MassHunter Workstation Software Qualitative Analysis B.04.00
Build Configuration: Release
Message: Se produjo una excepción en el destino de la invocación.
Stack Trace: en System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck)
en System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache)
en System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache)
en System.Activator.CreateInstance(Type type, Boolean nonPublic)
en System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
en System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
en System.Activator.CreateInstance(String assemblyName, String typeName, Boolean ignoreCase, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, Evidence securityInfo, StackCrawlMark& stackMark)
en System.Activator.CreateInstance(String assemblyName, String typeName)
en System.AppDomain.CreateInstance(String assemblyName, String typeName)
en System.AppDomain.CreateInstanceAndUnwrap(String assemblyName, String typeName)
en Agilent.MassSpectrometry.DataAnalysis.MethodSubGroup.get_Item(String key)
en Agilent.MassSpectrometry.DataAnalysis.DAMethodBase.get_Item(String usageKey)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.QualDAMethod.get_Item(String usageKey)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.AppManager.GetMethodPSet(String usageKey)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.AppManager.GetMethodPset(String usageKey, Boolean raiseErrorIfInvalid)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.QualCommandBase.SetSettingsPSetReferences(Dictionary`2 keyToCurrent, Dictionary`2 keyToOriginal, DataItem settingsDataItem, ActionItemCollection actions)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.QualCommandBase.RefreshMethodNodes(ActionItemCollection actions)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.QualCommandBase.OnOpenDAMethod(QualDAMethod qualDAMethod, ActionItemCollection actions)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.QualCommandBase.LoadMethodAndUpdate(String daMethodPath)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.CmdOpenDAMethod.DoSpecialized()
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.QualCommandBase.Do()
en Agilent.MassSpectrometry.CommandModel.CommandHistory.Invoke(ICommand cmd)
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.AppManager.Invoke(ICommand cmd)
en Agilent.MassSpectrometry.CommandModel.CommandBase.Execute()
en Agilent.MassSpectrometry.DataAnalysis.Qualitative.QualForm.SendSynchronouslyToAppLayer(QualCommandBase command, Boolean showOutstandingMsgBox)
Message: El método especificado no es compatible.
Stack Trace: en Agilent.MassSpectrometry.DataAnalysis.PSetAvailableReportTemplates.GetCultureSpecificTemplateFolderPath()
en Agilent.MassSpectrometry.DataAnalysis.PSetAvailableReportTemplates..ctor()
en Agilent.MassSpectrometry.DataAnalysis.PSetReportTemplateSelection..ctor()
Hi. At the end, were you able to solve the problem? I have the same too. Thnks in advance for answering.
Users browsing this forum: Google [Bot] and 12 guests
