Agilent1260 G1311B QuatPump Multi gradient assembly warranty
I would like to ask if any of you know how long the warranty Agilent gives for G1311B QuatPump Multi gradient assembly (MCGV)
http://thumbs2.ebaystatic.com/m/mFbbBgX ... Lg/140.jpg.
Polish distributor of Agilent gives only three months warranty. For such expensive part seems to be short.
Hi
I am not sure of the warranty but they should last longer than that, in fact they are pretty robust and unlike the Waters version you can push and pull solvent through ( within reason.. ).
What issues are you experiencing?
And yet, as far I know, Waters gives a year warranty.
My MCGV problems lie in the fact that the pump takes the solvent from the other channels. For example, when I set 100% A, pump takes sometimes a bit of channel C. As a result, I do not have repetitive peak retention times. Unless all channels are in the same bottle of solvent :wink:
Got an idea how to get an extended warranty for Agilent MCGV?
