Regarding analytical method validation
Is there is any specific order in which the validation parameters are to be performed (example starting with Specificity, Linearity, precision etc.) or can it be done at our convenience.
No particular order is required. It's a good idea to set things up so that you can get the most information from the least effort (for example., linearity and precision can be done from the same experimental data set (along with LOD and LOQ if those are required).
