Issue with flows - HP5890 series II
Hi everyone,
I'm trying to setup my old cromatograph. It's start up normally. The head pressure is ok. But I dont have all flows in the detector (FID). The air flow works properly, but the h2 and n2 dont appears (sometimes, the h2 work a few time). Anyone can help me?
Hi
Initially check that you have hydrogen entering the 5890. Secondly check the jet is not blocked, the hydrogen goes through the jet.
This accounts for most issues, get back to us if this does or doesn't work.
Hi
Thanks for answer. The jet was clean. I found the problem. Was the broken liner. It was a disruption. Now, the HP5890 it's new :D
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
