Empower Custom Field help
can any one help with this one...I have not had much luck doing inter sample/std calcs
Absolute Percent Relative Error
A1-A2/(A1+A2/2) x 100
A1 Peak Area of first std
A2 Peak Area of second std
thanks in advance
Brad
"Hey careful man theres a beverage here"
The Dude
The inter sample calculations must not be used by many people in the industry. This is our only instance.
The Dude
Use sample labels in your sample set method.
A1 = SS1
A2 = SS2
Formula: ((SS1.%.%.AVE(Area) - SS2.%.%.AVE(Area))/((SS1.%.%.AVE(Area)+SS2.%.%.AVE(Area))/2))*100
End your sample set methods with a Summarize Custom Fields function.
Replace Area with what ever parameter you are looking to use. I somewhat erroneously assumed you would use peak areas...
If there are not multiple injections, then I believe you can also drop the AVE from the equation.
For samples, given the number of samples, you might be best using an enumerated custom field as a function to calculate results.
Hi to everyone,
this formula would be perfect for me if you can help to rearrange it for me since I am new to Empower.
Alla I wanna do is to calculate the percent difference between the calculated amount of single injection and the amount value obtained as average of 10 injections. The final result would be a column next to the sample amount calculated by empower which says +0.2% or -0.3% with respect to the averaged amount.
How can I setup this custom field? which formula shall I use.
this the link related the result I wanna achieve
http://imagebin.org/298059
Thx a lot for your help
