mobile phase, HPLC
May I use more aqueous phase than organic phase for reverse phase HPLC column, such as C18 column?
like 60% aqueous phase, 40% organic phase?
I am an newer for HPLC. Hope it is not silly question.
Sophie
like 60% aqueous phase, 40% organic phase? I am an newer for HPLC. Hope it is not silly question.
Thanks, Sophie
Yes. We go low organic-high aqueous frequently as starting point for gradient elutions for polar species.
There are some C18 columns that cannot well tolerate less than 5% organic, so to go that low, check with supplier.
For a standard RP column I would recommend to follow the 5% rule. Keep always minimum 5% aqueous phase or on the other side 5% organic phase.
Users browsing this forum: Semrush [Bot] and 20 guests
