Cholesterol in fish oil
Hello friends!
i work with fish oil.
I do analysis of fatty acids. fames
Now I have a new challenge, analyze cholesterol fish oil.
I have tried to carry out the method of AOAC 994.10
but I have problems.
the peaks both cholesterol and 5 alpha cholestane are not defining me very well.
I do the analysis in gc-fid with a methyl silicone column series quadrex.007
I use a liner with glass wool.
I use a temperature ramp to 170 ° C 1min 7 º C / min 261 10 min 15 ° c / min 320 ° C 7 min (total time: 35 min) detector 350 º C carrier: helium 22.4 psi detector gas: hydrogen 40ml/min Air 400ml/min, injector 340 ° C. injection 1ul
I use a perkin elmer clarus 500.
How the calculations are performed for this analysis?
Do they have some method for the preparation of these samples?
What liner should I use?
Can anyone help me with TotalChrom to load with calibration curve?
thanks for your reply!!
I haven't assayed cholesterol in maybe 20 years. I did use cholestane as internal standard and I did make trimethylsilyl derivative of cholesterol (cholestane does not derivatize). Yes, I did use capillary GC. And the assay worked well.
Back then the "official" method used benzene to extract, we used toluene. Don't know what any current or newer methods use.
In total there are 32 users online :: 1 registered, 0 hidden and 31 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot] and 31 guests
