SPECTRA IN NORMAL PHASE HPLC
Hi all!
Is it normal that PDA-spectra for compounds when working in normal phase are worst than the ones in reversed phase HPLC? :shock:
Is identification of compounds from their spectra still reliable in RP-HPLC?
:o
I noticed that there are some changes between spectra maximums from RP to NP-HPLC (I work with tocopherols & tocotrienols)
thank you in advance
Carmen
I don't know what you mean by "worse".
There is no reason to expect exactly the same spectrum in vastly different chemical environments (aqueous vs. non-aqueous), especially if the chromophores are coupled to ionizable groups.
UV spectra are generally are "information poor". I would not rely on UV spectra for positive identification under any circumstances.
Users browsing this forum: Semrush [Bot] and 9 guests
