HPLC column packing station
I would like to buy a HPLC column packing station for columns of 20 mm ID. Anyone kwons a supplier???
J.
Prochrom (now Novasep)
Knauer
E.Merck
J.
You may also explore, Restek's "Pack in a Box" kit which is very convenient for academic purposes. Constant flow or constant pressure modes can be applied.
Hallo
Packing stations are typically starting at 25mm I.D. - So it can be more economical to go with 25mm I.D as most suppliers can deliver it.
I did a 20mm packing station once as a special project. If you really need 20mm, maybe I can help you.
best regards
Chris
Users browsing this forum: Semrush [Bot] and 6 guests
