purchasing used hplc. HP1050 or PE200
Hi im looking to set up and run a used instrument. Do you have a recomendation of one instruement and running system over the other
HP1050 and older chemstation
or
Perkin Elmer 200 and Total Chrom ?
We had up to five 1050 systems. Only one is still in operation. The others didn't "die", supervisor just wanted to update to 1100 and 1200 systems and do LAN connections and OpenLab.
So 1050 systems are pretty reliable. Don't know about other brands. Older chemStation is fine, use on older computer. Your results will be just as accurate.
there seems to be a lot of people putting down total chrom on here.
I had an PE200 system back in the '90s. I didn't mind the Turbo/TotalChrome. The one part that wasn't so reliable was the old style autosampler. Until it was on UPS it had frequent problems.
HP / Agilent has (and had) a much larger market share than PE, which means that spare parts availability should be better. Same comment applies to expertise: there are a lot more people with Chemstation experience who can give you answers here on the Forum.
Edit: I see from your other posts that you already have a 1050. Unless you're unhappy with it, it would make sense to get another one so you don't have to have two sets of spares, methods, etc.
The HP 1050 and chemstation is a much better system, easy to get parts for and very reliable. Please let me know if you would like me to provide you a quote on a refurbished 1050 system.
Best Regards,
Alex Hummell
Analytical Instrument Management
ph. 303.730.4136 ext. 902
cell. 720.203.5224
http://www.AIManalytical.com
