1/4" Nut for Agilent Make-up Gas Adaptor
For an Agilent uECD make-up gas adaptor, is it better to use a brass or stainless steel 1/4" nut?
Thanks!
If this is a Swagelok female nut (as I believe it is) then it is not wetted and either material will work just fine.
What exactly are you concerned about?
FenderChrome,
We commonly use brass with copper tubing on the make-up on the ECD. The SWGLK part number for the nut is B-200-1 and the corresponding ferrules are B-200-SET. The carrier gas is inert and doesn't react with the tubing or nut.
Warm regards,
Jed Sullenger
Custom Solutions Group LLC
1419 Avenue A, Katy, TX 77493
Telephone:
(O) 281-574-9999
(C) 832-540-9127
Fax: 707-215-0932
E-Mail: jed.sullenger@customsolutionsgroup.org
In total there are 28 users online :: 0 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 28 guests
