empower question
HI Guys,
I acquired data on a dual detector on two different wavelengths. When I open the data file how do I know which wavelength I am looking at and how do I see both for integration? Thanks
Hi Shadow,
In the Samples Tab, the injections should be marked with the channel/wavelength that was acquired...so you can take the set(s), one at a time, into review and process them. When all is well, you'll re-process, maybe needing to use two processing methods (if the peaks are "substatially different" at each wavelength) and you'll get two distinct Result Sets.
Please, See What You Think, and Good Luck!
MattM
thank you!
