Aux EPC vs. PCM
Can someone please explain the difference between Aux EPC and PCM?
Thanks and best regards,
W:
The PCM is a two channel device.
Channel 1 can either be set up to run as a flow controller or as a forward pressure regulator
Channel 2 only controls pressure. It can be set for forward pressure control or back pressure control
AUX press is a 3 channel device
It only contrlsl forward pressure.
Gasman
In total there are 31 users online :: 1 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot] and 30 guests
