Chemstation batch report error: cannot load data file
I use the batch report in the Chemstation Software quite frequently. Until now everything worked fine. In one run the data file is missing (I do not know why). The batch processing stops with an error message : "ERROR: Processing Run: Error during batch processing: Data file xxxx.D not loaded"
i do not care much about this missing data file. I would like to have all other runs exported. But the processing stops and nothing is exported.
Does anyone know a solution ? (Chemstation LC Rev B.04.03 (16) )
you could try copying one of the existing files, giving the copy the name of the missing file, and see if Chemstation notices...
Then exclude missing file from batch processing.
