Reasons for Using Flat Tubings on UHPLC
8 posts Page 1 of 1
I am attaching a picture of a commercial UHPLC pump head. Does anyone know the reason for using such a design? It is intriguing.
Note the flat S shaped tubing going from mixer to the pump head.
Thanks.
Hello
You have pump that can run up to 1200bar so a lot of heat is generated during solvent pumping.
This S-shape flat metal "thing" is heat exchanger.
Tomasz Kubowicz
Hello
Tomasz Kubowicz
Really ? That flat piece of tubing goes from proportioning valve to pump and it is not subjected to any heat resulting from solvent pumping.
Hello
[/quote]
Really ? That flat piece of tubing goes from proportioning valve to pump and it is not subjected to any heat resulting from solvent pumping.[/quote]
Yes, you're right. Flat "tape" between MCGV and valve is Inlet Weaver.
I thought the question was about highlighted part of pump.
Tomasz Kubowicz
Maybe one of the engineers at Agilent in Waldbronn will find the time to answer your question.
As Tomasz said it may function as dissipation of thermal effects accomanying mixing ACN with water - althou I always thought this effect is negligible.
My guess is that it is a low volume mixing chamber, probably with some fancy internal architecture.
Hello
It is low- pressure Inlet Weaver based on patented Agilent microfluidic technology ensures highest mixing performance and lowest mixing noise :)
Tom
8 posts Page 1 of 1
