P/V ratio_ Empower 3 software_HPLC
Dears,
Please let me know how to calculate peak to valley ratio thru empower 3 software..
Activate the SST-calculation* and select "all"
Then you'll get the p/v values for the start and end of each peak.
To display/print it, you'll need to edit the columns of your peak-tables
*SST option needs to be installed in Empower3 and enabled for your project
In total there are 4 users online :: 2 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 2 guests
