I injected a sample that (apparently) had too much iron in it and contaminated my system. I've cleaned up the column and supressor now, but I'm wondering: how much iron can I have in a sample and still be safe to inject? My samples are about 20-30ppm iron, but I want to dilute as little as possible so I can still see the anions.
FYI:
Dionex ICS-2100
AS-18 column & guard
ASRS 300 supressor
CRD-200 carbonate removal
1mL/min 12mM-52mM KOH
Ideas?
