Integrate and Label Peak Areas Error
1 post
Using Agilent Data Analysis E.02.02.1431. I have noticed that occasionally when I select the menu option "Integrate and Label Peak Areas" it will not label all of the peaks on my TIC with the area values. The retention times will all be labeled, but only a few peak areas will be labeled and there will be an error message on the bottom that says "Value out of range: 86206" (or some other number). Using the same processing method on another data file it will work fine. Does anyone know the root cause of this problem? I looked at the macro file that controls this function but nothing is jumping out at me.
1 post
