P/ACE MDQ CE Sytem, Coolant low message
Discussions about CE, MEKC and related topics
Hi all,
We are using a p/ace MDQ (Beckman) since 4 years. Recently, a strange message appears from time to time "coolant low". A verification of the coolant level showed that it was OK. What is the problem at your opinion?
Thanks in advance.
The level sensor, in the coolant reservoir, its broken or sends wrong measures. That is probably the point. Check the level sensor position.
