Gas flow issue
Having issues with a 6850 GC. It can't maintain gas flow setpoints for more than about 2 seconds. The gas flows fall to about half their setpoint values after a couple seconds then fall even further. After maybe 20 seconds the machine tries again and the same thing happens. Any ideas as to what I can try to troubleshoot the problem? I had contacted Agilent about this problem last year and they said the EPC valves are faulty but would like some more opinions.
When I came back from working over a weekend, and somebody had tried to run a bakeout with very little hydrogen left causing an influx of oxygen before everything cut off. The oxygen(in a hot oven) caused a fracture in my silica capillary column(pretty old column) that was not visible until I tried to move it to check and a piece fell off in my hands. I would try moving the column some before getting into anything too extensive , and see if there is any damage. I ended up using a ceramic wafer to cut the fractured piece to a flat edge, and put it back. Ran solvent through to clean it up and adjusted the retention time, and it was as good as new.
In total there are 30 users online :: 1 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot] and 29 guests
